CharlesOK, you were right on about the mud dabbers. The burner tube on the frig was plugged solid, that is why it would light then go out. Cleaned out the mud and it been running all day on LP. I will also check out the furnance for those critters, but it's in the high 70s here in the Shenandoah Valley, so it's not a rush.
Bobcote48, did you pass thru Winchester VA in March? We were in the process of buying our 213 but had not yet picked it up when we saw a Trail Lite on General Jubal Early Drive (U.S.50) which is Exit 313 off I-81. We get a lot of RVs at the Wal-Mart and I looked later that evening but there were no T/Ls there.(I would have said hello and told you where the best ribs & BBQ place was located and invited you to join us) Winchester is losing some of it's old time southern charm as it becomes a suburb of DC but it's still got a couple of good rib joints.
Has anybody encountered this. The generator starts from the switch on the unit itself, but only spins the starter (no start)from the switch inside. I suspect a voltage drop type problem but haven't chased any wires yet. This unit sat for a year after the original owner died so it may be oxide on those wires (can't blame mud dabbers on this one)
Planning a Memorial Day trip to Westmoreland SP (birth place of G. Washington and Robert E. Lee and a July 4th trip to Lake Chautauqua NY (DW is a yankee.) Hope to have all the gemlins out by then.
