Hello All
Just finished a 6500 mile, one month loop around midwest, eastern/midatlantic, and southeastern US – 23 states in all, with 2 nites in provencial parks along Ontario’s Lake Superior shore. First really long trip where we did SPs, KOAs, driveways, and no-hookups at all at Shenendoah National Park.
Trail Lite was just fine, and its size was great for short driveways and tight parking – don’t know if I will ever want a very long rig, or one with a toad.
Have determined that the overhead squeaking is more than likely styrafoam(?) between the headliner fabric and the metal cab roof, so I will need to look back at posts where one of you described something similar.
I must get an alignment as the left front tire shows more wear on inside and a very slight tend to pulling left. Had one at 4k when tierod nuts were discovered loose from factory – rig has 20k miles now. Am thinking to use the 2.5 year old but never used spare on right and swap the right to the left. Understand that leaving dually tires alone is a good idea. Thoughts??
BTW, could not locate the new B+ Forum.
On Edit
I discovered that I had to access the Open Roads Forum via RV.net instead of thru Good Sam's Forum link - for those having trouble finding the new B+ Forum.
