I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
burlmart - I don't have an answer whether it is a good idea to leave dually tires alone. I did not and so far have not had any major problems. My right front tire started cupping at around 20k miles, I swapped it with the inside right rear. I then installed Bilstein shocks in front thinking the cupping was due to bounce or hop. I have noticed no additional wear since.
I suspect you might need an alignment when fully loaded as the spring height will change the camber of your front wheels.
