Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
happyjack2 wrote:Finally found your posting after I looked at my unit. I have the same type of connections on the frame behind the rear axle on the drivers side...and I would bet the connections are for the converter.
I was under Happyjack2 routing wiring for a new electronic toy and I found three ground wires that were broken free of their grounding point. The self tapping sheet metal screw holding the the lug ends had broken off where it was drilled into the frame. Just aft of the leaf spring mount above the tail pipe. If it was loose last year that may have been causing my intermittent problem with trying to start the generator from inside.
