When I removed the 24 inch TV from our BT I opened up one of the biggest cabinet area storage compartments we have inside. A little masonite to finish it off or any light weight plywood and while there stuff it good with insulation as there is virtually none and it sure makes a difference in summer heat. I mounted my tv at the other end of living area but mine is 27 ft. I used a double swing arm I purchased at Wal-mart. At first it was a 15 inch and now 19. This swing arm will rotate the tv 360 degrees so I don't see why you couldn't mount it under the cabinet. With the lcd you have so many options depending on your needs but freeing up that space where the large tv sits is great. Good for you making the space work for you. We took out barrel chair and use two of the folding recliner with built in foot stools that pull out. They are comfortable as any chair in my home, travel easily and can double as outside furniture and if something happens to one it goes in garbage and the 89 dollars it cost is not nearly as expensive as red wine on a good chair. I went through many lazy boy possibilities until I realized the solution was under my nose.
