The recliner I referred to is 89 dollars at camping world. It is outdoor but very nice. It has a cushioned seat and back with nice metal frame. It can be used as a chair, the back tilts back as far as you could want. It has a leg rest the slides under the seat when not in use. When in use it pulls out and two legs fold down to support it. So you have a chair that reclines or not and an ottoman that only takes up space when in use. It is about 25 inches wide so fits in most small places. I like the ability to recline the back a little when not using the ottoman. You can probably see it on line. It is a red and white stripe cushion. I have gone through many chairs both in and out and this one is really comfortable to me. Now regarding TV. The tv for computer works fine but you are tethered to antenna so walking around not so easy. I use a slingbox a great deal. This is a device hooked to my home wireless network and cable tv source. I can then access through internet and manipulate my home tv. Does require a decent broadband connection. I use it a little on my verizon card but streaming video uses a lot of the monthly 5 gig. By the way I purchased doors and the match was easy in terms of stain and put them on the space. Looks like original. Most home improvement places have doors and these are common style. As you know your antenna hookups are in door on passenger side but when you remove the big tv the antenna will be there. I have not found an arm for drop down or fold down for the bit larger tv. you can get kitchen tvs that drop down but they are 8 inch or so. Personally I like the option of putting the tv wherever I want it and stowing it when not in use. A quick connect on the antenna and bit of coax and you are good to go. I agree on the horizontal services of cabinet if you want a permanent mount.
