Well, to get a bit technical, I am an electrician by trade, industrial mostly.
But, the resistance within a circuit is made up by all the individual parts. Heat is calculated as I (current)² times R (resistance in ohms).
Normally wire and connections to and from the load would only add possibly 1/10 of an ohm or so over the entire length of the wiring and connections. Spread over all the wiring you can calculated I²R to be at 30 amps 30 X 30 X 1/10 = 90 watts
But if you have a weak link, like a frayed connection in a molded plug, or a loose connection in a buss bar, that loose connection may individually cause a resistance of a half ohm. Suddenly just in that one spot you have 30 X 30 X 1/2 = 450 watts. Knowing how hot a light bulb gets, imagine all that heat on that melted buss bar, or feeling that hot plug, imagine how many light bulbs it would take to get that hot.
The most dangerous part of all this is that the voltage starts out at 120 volts, and when the circuit is running fine, the loads on the line see almost 120 volts. But when you have a load like a bad plug or a melting bussbar, that load takes (at 450 watts) about 15% of the voltage, leaving only a little over 100 volts to run your fridge, air cond, etc... The available power in the circuit is robbed by the faulty connection, so everything else doesn't get the power needed to do what it's supposed to do. That causes compressors to struggle with trying to overcome the built in resistance, the more it trys the hotter it gets, the hotter it gets, the more resistance in the wires, until something gives...hopefully the breaker trips before the motor burns out.
