Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
cheeze1 wrote:I don't have any pictures, but my original 19" analog TV was completely enclosed in the cabinet above the cab. I carefully removed the screws for the roll-up and the restraining frame around the TV. Removed and gave away the TV. Could not find a good place for a digital/analog converter that would have line of sight to a remote. I carefully created a paper template of the floor in the TV space and made a false floor out of 3/8" plywood. Wanted something a little more substantial to be able to attach a regular 19" digital television. I used the base that came with the TV, temporarily removed the plastic cover from the base, and drilled some holes through the steel plate. Then put 4 bolts through the false floor with threads sticking up. Placed the TV on the bolts and used the self locking nuts to hold the TV on the false floor. So far, works and looks okay.
Hi Gang, I'm going to do a couple of mods:..
2-I don't like my method of putting the tv on a shelf/bracket for travel. I'm seeking a flatscreen mount and will mount that to a piece of plywood hinged at the top so I can fold the tv up and back from the bottom, and have a clear floor to the tv box...
Thanks all!!
