Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
cheeze1 wrote:You know what is frustrating, is a small corner comes loose by itself, but if you want to remove the rest....well it just does not want to budge. Been tempted to use a sander. But, with my luck I would get into the wall paper or gouge too deep or not deep enough....Aaaaah.:h
...I tried to remove that 'decorative' tape stripe that goes around the coach about 1/2 way up. I thought for sure I could cajole it off nicely and then put something much cooler or do without. The glue stuck to the wall and the plastic pulled off, and as you know, getting those kinds of glue off is a royal PITA. So instead I'm going over it...
