Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
audreyv wrote:No snow, huh? Some of us can't even get to our RV until the weather warms up and melts the snow. Our RV is stored indoors, but the main door of the building is about 75' from the street. The street was plowed by the city and left a ridge of snow about 4' high and hard as a rock next to the curb. Can walk to the building and go inside to check on everything, but unless we hire a tractor or skid loader with a scoop likely will not move the RV out.
No snow accumulation here in the FL Panhandle, but did get a few large, fluffy flakes a couple of days ago...This little Trail-Lite B+ 211S works just fine for the two of us. Only a problem cropped up...The inside seal of the slide has cracked, most likely from the tension of the 'tension bars' used to prevent the slide from opening while vehicle in motion...Has anyone experienced this problem and did you have to replace the whole seal? Thank you.
