I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
Chaz, look at the paint can for the paint you used to see what the main solvent is. It's probably xylene. You can try a commercial paint stripper then clean any residue with xylene. Test an inconspicuous area first with both chemicals. The fiberglass gelcoat is pretty stable and "should not" be affected by either chemical if not on too long.
Yah, I considered masking off a swoosh, but I guess as you found out, it's just too hard to get a smooth curve with tape.
