Daniel_C_
Feb 25, 2002Explorer
B+ motorhomes
I just bought a Trail Lite B+ 211s with 8.1 Chevy engine. This is my fifth motorhome (others range from an old 20' Vagabond, and three Winnegagos, from 19 to 32'. This vehicle is fantastic. I am...
burlmart wrote:Sounds like someone should be able to come up with a solution. How about temporarily covering the roof and sides of the RV with a painters drop cloth. Then drive under a horizontal boom* that would spray either a fiberglass layer or something like this Rhino pickup bed liner onto the drop cloth. When it dried, trim it up and you would have a negative mold of the contour of your RV roof. It should be light enough for two people to toss it on the roof. Don't know where you would store it while using the RV. I do know that they make small trailers by spraying fiberglass over a negative mold. Only need about 1/8" thick or less.
I often think there has to be a simple way to frame up a 'hat' to cover the roof of our small rigs. It would need to be light enough to take up there and set in place...
