New Question gang. Last year I had an alarm installed in the 213. Works great, added protection when we leave the pups alone for an hour or so. Problem is when I have it in storage, it wears the chassis battery down and I have to use the coach battery to start the engine. It's happened every time I check on it in the storage lot since I got the alarm. Last time, the engine seemed to 'run weak' and sounded like it wanted to stall if I didn't stay on the gas. Is that because the battery was so run down? Should I install one of those toggle switches onto the battery so it doesn't run down? I know the alarm will be disabled, but it is in the same locked lot it's been in since '05. Thanks!
