Lenc. With double slides, the Ford chassis is probably the better chassis on your unit. You will have greater GVW than mine has on the Chevy chassis. I really did have a good experience with the Trail-lite product and can assure you they are built on the same line, by the same Techs, with the same materials as the Holiday Rambler/Trail-lites. Welcome to the Family and hope you enjoy yours as much as we have enjoyed ours. As far as the BAL product goes, make a final inspection with the selling dealer and assure yourself that is what is installed in the one you are buying. They were using the new slides in all units when I was at the Factory in July, but all manufacturers use up existing supplies of what ever they have when they build units. If your new one is a 2006, built earlier in the year it may have been built with slides they were previously using. Not to say that the previous slide product was bad, just not the new BAL units, which IMHO look like a good idea from an engineering standpoint. I sincerely hope your NEW buying experience with yours will be as good as mine has been since last January 16th when we picked ours up. One way to tell if your looking at an early 2006 as opposed to the later product is to look for a Pull-out slide tray for twin batteries behind a flip-up door that includes the bottom trim on the body. Early 2006 production units had a small door and only room for 1 battery. no slide-out tray. Really a nice feature that was a line change item during the production run. Mine has it and I installed a second Allstate battery to match the first. I saw a new 2006 for sale at Emerald Coast RV , Navarre Beach, Florida in February with the older small door, single battery set up. That's the only reason I know that they changed it. Mine was built 12/2005 on special order and I believe they put the slide-out tray in anything built after that time. May not be an issue, but it would be a quick way to tell if yours has the latest specs. Unfortunately they dropped the Mor-ryde rear suspension for the 2007 production run. I ordered mine with this extra and feel it was well worth the extra.
