Well, I tested some things, and the camera is operational! I need to mount the flat screen, which is going to take some carpentry. And mount the 110V outlet which isn't a biggie. I will have two inputs for the tv....the camera and the dvd player. So I think I am going to need an rca switch. Unfortunately the tv only has one set up rca inputs.
Then I need to figure out how to watch from the rear tv, as it only uses coax. So I need to convert rca signal to coax, and use a splitter to feed both TV's. Probably would be best eventually to replace the old tv in back as well with one that incorporates a dvd player so it is independent of the front.
