The system in my coach was DOA on purchase. Was a B/W camera and CRT monitor in the dash. Replaced it with a color camera and LCD monitor for
THIS SELLER. Less than $100. They based in Hong Kong and I pay via Pay Pal. The system came with a new cable between the camera and monitor that I used. The old wire is somehow held in place inside the rear cap so I just cut as much as I could get to. To get the new cable in I used a snake between the upper corner running light to pull up to the top of the cap then again from where the camera is mounted to the light.
The new monitor was a bit smaller than the original so I used thin ply as a mounting adapter. Finish dash -
