fcooper
Jan 25, 2014Explorer II
I've purchased several components from this vendor and they seem to be good quality. I have a monitor and camera in use for several years. These systems will have screw together connectors
camera/monitor vendor
I've also had good luck with cheaper components from ebay. Most of them will have plug together connectors. As long as the connector is inside the vehicle and you secure it from vibrating loose, they will work well.
Don't under-estimate the length of cable you need. To go down the back cap, along the frame rail, and up into the cab the 65 foot cable is about right.
Fred
Fred
38,778 PostsLatest Activity: Jun 06, 2026
