I replaced mine. CRT based monitor contrast was failing and washing out the image. Replaced with a flat screen LCD from
AMAZON. The coach camera is wired but I did install a
WIRELESS on the toad so I can see behind it should I desire. The toad transmitter is in the CRV rear door and the receiver is in the coach dash and I get a reasonable signal at about 45 feet.
The problem you'll face with wireless is you'll still have to power the camera off a source that you can turn on or off. I like having the camera on when going down the road so my system is chassis powered from an ignition key switch source. Engine on camera and monitor are on. The toad camera is powered from the coach when connected.
The new monitor wasn't a perfect fit for the hole in the dash but I hide everything pretty well. Used light ply as a mounting adapter and painted the front side black.
