Update #2: I removed the inline fuel switch. A few drops of fuel dribbled from the line. I thought this was odd. I expected a flow. Does fuel flow depend on the generator’s on board pump?
Anyhow, I primed the carb. I can heard the primer pump running.
I then tried to start the generator. It fired up on first kick.
Once again it ran for two minutes and then quit. I have a feeling that it uses up the fuel in the float bowl and then just runs out of fuel.
So, should the fuel line remain empty until the generator draws fuel? And, if so, why isn’t fuel flowing? The system seems to prime normally. Could it be a generator fuel pump issue? Maybe the little critters ate a wire I missed??
