How do I know if my converter is bad? I has a slight buzzing sound coming from it. The fan is spinning. My slide comes in and out slowly as well. I want to clean the battery cables. They look fine b...
Removing the negative first is safer because you might touch the frame or any grounded metal around the battery with the tool your using while trying to remove the positive first.
