AikenRacer2
Nov 04, 2022Explorer
Bad Lippert O ring
I have had a small hydraulic leak from the pump system for a while. I finally narrowed it down to the o-ring between the plastic tank and the pump itself. It's a 3.5" o-ring. Looks like whoever installed it did not get the o-ring in level all the way around as it had a twist in it. Ok, I'll just get a new o-ring from Lippert and replace it. Well, much to my surprise, Lippert will not sell replacement o-rings. What a crappy way to treat a customer who spends mucho money on their products. I could probably rotate the o-ring to the top so that it's above the fluid level but I'd rather fix it right. Other than Amazon, where could I get a replacement O-ring that has a flat surface? Lippert stinks!
