Mfreyder's avatar
Mfreyder
Bad Vibrations
Bought a Four Winds Chateau Sport a month ago. Coming home we had a bad vibration that turned out to be a bad tire. RV had new tires on the front, 2011 tires on the back. Replaced all four tires on the back so we knew we had good tires to start.
So the bumping went away, but now we have a vibration that is shaking the microwave to death. Microwave floats, held in place by a face plate that has braces going around the back, and the face is held by four screws to the cabinet. On a recent trip we had to remove the microwave to be able to hear ourselves think.
Question is what is causing this vibration? Drive train vibrations? Drive shaft? Anyone have experience with this problem? I'm heading out to check U joints today. Suggestions?
Thx
  • While you have the tires off for checking balance and run out, also watch the wheels on the spin balancer to ensure the wheels are straight and watch the tread while it is spinning. I seen both improperly mounted tires and defective tires that showed excessive tread wobble. The tire shop should have caught any of these when they mounted/balanced the tires. If no joy after checking tires/wheels and drivelines, you may have to check run out on axle hubs (rarely a problem unless something bent an axle).
  • Chat up some of your friends or mechanic who know the difference in the feel of a wheel balance issue vs. a driveline vibration. Go for a drive-they generally are distinct from each other. Driveline vibration is generally higher frequency than wheel balance, but both are relatively low frequency. It is hard to describe but driveline vibration is frequently audible as a low frequency constant booming noise, possibly a rumbling. In a bad case it could cause stuff inside to rattle with the vibration/sound. Wheel balance is lower frequency (wheels turn slower than driveshaft).. more of a shake which can also set off rattles.
  • the_armadillo wrote:
    While you have the tires off for checking balance and run out...
    Actually, you want to check run-out with the tires mounted on the vehicle.
  • j-d's avatar
    j-d
    Explorer II
    This is gonna sound stupid-simple, but...
    Make sure no foreign object got trapped between wheels and hubs or between the faces of the dual rear wheels.
    I had a tire installer pinch a braided valve extender between the duals. He caught it right away and replaced it but I imagine such a thing could cause a wobble.
  • On some Fords they use a compression pin as a guide for the rims. Is it possible that the pin was not aligned when the tires were changed?
  • j-d's avatar
    j-d
    Explorer II
    I think Ford used that pin in the rear hubs till about 1984. At least our 1983 chassis used them and it didn't seem later years did. The wheels weren't hub-centered (aka hub-piloted) but rather they were "Coined". Every other lug hole was recessed or raised. Inner wheel's recess had to match outer wheel's raised and the pin lining up in a hole assured that.
    OP is saying it's 2007, so I'm pretty sure there's no pins. Our 2002 doesn't have them. There's still an extra hole but I haven't figured out what Ford meant it for.
