Passin_Thru
Jun 19, 2013Explorer
He aske how to repair it! Take a router with a small bit and grind out the damaged area only the depth of the fiberglas.. Take an electric sander and taper the edges. Buy a bondo kit and mix the fiberglas according to the instructions, cut the fiberglas a bit bigger than your ground out area, dip the fiberglas in the epoxy using proper gloves, not latex, and smooth it over the hole, don't over use the epoxy or it will drio and is hard to remove. After it dries chec to see if it filled the hole but it will probably take 2 fiberglas applications. Sand with 300-500-700-1200-1500 grit sandpapers and slowly smooth the surface. Fill with a gelcoat from a marine place and paint.
see http://adventure.howstuffworks.com/outdoor-activities/water-sports/how-to-maintain-a-boat1.htm
