Marv_Hoag
May 06, 2019Explorer
Balancing Rear Tires?
Getting 6 new Toyos. Last time the only tires I had balanced were the fronts. Is this what most do, or do you have all 6 balanced? Not balancing the rears saves $100.00.
DFord wrote:
If you put that **** in your tires, be sure to let anyone that works on that tire assembly know in the future before they do anything to it. It can make problems for them if you don't.
You'll need filters on your valve stems to keep it out or your tire gauge.
