rgatijnet1 wrote:
If I remember right, there were TWO different ball joints that were listed for the P30 chassis. Both would fit even tho one type was a little smaller and would wear out quickly. Compare the two ball joints and use the ones that are the beefiest and they should last a long time, with reasonable care.
I believe the one type of ball joints was listed for trucks and the other ones were listed as RV specific. Hopefully someone else will chime in and clarify this discrepancy.
X2 and if you use the wrong ones they will fail fairly quick.
I use to have the correct part #s I will look to see if I can find.
