balfre1946
May 21, 2013Explorer
Baltimore Tunnel etc.
We are in a 36ft Fleetwood Fiesta Class A with towed driving up from DC through Baltimore to Flemington, NJ..can we drive thjrough the tunnel or do we need to drive around Baltimire?
Simple answer is if the tank holds more than 2 gals or 10 pounds, you have to go around the west side, or use the Francis Scott Key Bridge. The controversy arises over the use of the propane. If the engine is powered by propane as its fuel source, then the restriction does not apply. If the propane is used for cooking and heating (which is typical in all RVs) you will need to take the long way around.
