Trackrig wrote:
I'd take the shock off and go for another test drive.
I know you said it sounds like right where the wheel is, but do you have a sway bar that can be loose or broken on the left side, or the sway bar's rubber on the left side has worn out?
Bill
I removed the shock and went for another test ride but still have that clunking noise or rattle when going over a pot hole or a series of pot holes. The shock bushings looked good and they took about 75 secs to fully extend after compressing. The sound goes away when brakes are applied. The sound is on the passenger side under the seat.
