Tom_Barb
Nov 27, 2016Explorer II
usersmanual wrote:
like I already said; two different systems on different engine designs
the ISC banks was not a bigger turbo by the way.it was a redesigned turbo body but when the kit is installed it used the same actual turbo guts and also they never made a different intake system.you may have had a different air filter system of some sort?
this system is no longer available
I have both the turbans, the Banks is visually bigger. and as per the manual is allowed to produce higher pressures. The fuel schedule is modified and gives us better fuel milage than the stock fuel flow.
And yes I know it is no longer produced or supported, and banks has no system to replace it.
