usersmanual
Nov 27, 2016Explorer
Tom/Barb wrote:usersmanual wrote:
like I already said; two different systems on different engine designs
the ISC banks was not a bigger turbo by the way.it was a redesigned turbo body but when the kit is installed it used the same actual turbo guts and also they never made a different intake system.you may have had a different air filter system of some sort?
this system is no longer available
I have both the turbans, the Banks is visually bigger. and as per the manual is allowed to produce higher pressures. The fuel schedule is modified and gives us better fuel milage than the stock fuel flow.
And yes I know it is no longer produced or supported, and banks has no system to replace it.
yes;; read what I posted;; the turbo body is a redesigned unit.The turbo guts are the same.The actuater is different as this is what creates the higher pressure monitored by the add on fuel management system ecm and the egt
As said I never noticed better fuel mileage but tons more power and pressures as high as 37-38 where stock its around 28-30
I got 7.5-8 before and after system
