My 2000 Fleetwood Bounder with Ford V10 is running fine but now has 50,000 miles on it. Should I be considering an overhaul and if so do you think I should spring for the Banks System? I realize I may...
Send oil samples for testing to Blackstone or other lab and if really concern, run compression check. That will tell you a lot about engine condition. Banks do improve engine performance. Usually owners enjoy the extra power, but extra power cost fuel. Would you stay with the same speeds/accelerations you should notice mpg gain. Will it be worth the investment?
