Its quite possible the plugged filter caused the issue.  There are various lockouts that come into play if the AC ices up, other issues can cause a lockout that resets after 2 hours.  I'd certainly give it a try again before pulling off panels.  When I first read this I thought of a bad thermistor wire/sensor which controls the defrost/icing cycle.
FYI, the filter should only be a basic fiberglass-type filter, the cheapest kind.  The better filters that are cloth-like restrict the airflow too much and are not recommended by the AC manufacturer.  I've read that a high-filter HEPA type can restrict the airflow so much that is causes issues similar to what you describe.
There are many manuals for the AC heat/pump
here that might be for your unit and give you some help.  Many have troubleshooting flowcharts and other schematics.
