AikenRacer's avatar
AikenRacer
Basement floor replacement under fresh water tank
The floor underneath my fresh water tank was rotten. Just demo'd it. Pulled out the water tank. Plan is to clean up the metal support structure, put in a new floor and install the water tank back. The replacement floor will be about 4x8' with a cut out for the dump valves. Couple of concerns..
1) What do I use for the flooring? Need protection from road hazards on bottom and it needs to be strong enough to support a 6' x 4' vinyl water tank (there are 2 metal cross braces). Thinking about a sheet of marine plywood.
2) There was no drain anywhere on the old floor. Should there be one and if so, what kind?
Any comments welcome.
Thanks!
  • I would be cautious about using aluminum over steel cross braces. I'd worry about galvanic reaction.
  • Hi there, according to me, you should go for thick marine or wolmanized plywood. You can also hire a professional who can also guide you the right thing about the flooring. Recently my friend moved to his new house with the help of professional http://movingrightalong.com/business_service_pros.html movers in nyc who provided him moving and flooring service. According to him, they were friendly in nature and provided him quality driven services.
  • We have been using a product from GE Poly they call "puckboard" intended for lining hockey rinks(the boards) Comes in 4'x8'x1/4" sheets at about $100 each, and appears to be HDPE. Comes in yellow, white. blue, black, and a few other colors. Tough, handles 100 mph hits from hockey pucks and hits from skates and sticks. We have used it for signs that have been up on telephone poles in all weather for ten years now and still look new. It's what I'd use anywhere wood might delam or rot.
  • Yes, I did use the HDPE. It was easy to work with, easy to cut. From what I have seen so far, the industry should use it more for RV basement flooring.
  • Years later I have the same issue with a 2000 Newmar Mtn Aire. What did you end up doing?
