MartyW's avatar
MartyW
Basic Class A questions - looking for used 1997-2002
Hi to all,
My wife & I have been going back and forth for the past few months about which type of used unit to purchase which is within our budget. This purchase will probably happen in the Fall, Winter or Spring, to be ready to use it next summer. We've been watching ads and we're now seeing prices getting more attractive.
Through the years we've had a pop-up, travel trailer, older small Class A, and an older 26' Class C, and we now have a 20' hybrid. This time we've considered MH to TT and back again, and now we're pretty sure we want to go ahead with a 1997-2002 Class A within the $30k'ish range. The Class A gets us the levelers, storage and generator that just aren't available with a TT. We've had used before so used doesn't scare us. We'll of course make sure to get a unit that has lived in the south or southwest, no rust, hasn't set up for years without use, decent service records, no major damage, etc...
I have some basic questions on these years of Class A's as they are newer and larger than anything we've had before. We're most probably looking at 33'-36' length, and we're definitely looking for only a Chevy chassis since those years saw the first Ford V-10s come in with the plug issues. We know those plug issues were resolved long ago, but in the year models we're looking at, its got to be Chevy, preferably the 8.1L Workhorse, or (if we can't find the right 8.1L), a 7.4L 454.
Here are the first questions:
.) What is the chassis difference between a '98 7.4L Chevy and a 2001 8.1L Workhorse? Was the Workhorse heavier and/or wider? Did it drive/ride better? How was it different?
.) Was the Allison transmission only available with the Workhorse 8.1L, or was it also available on the late 1990's 7.4L models?
.) Since we're looking at the longer units, we're looking at 2 roof A/C's and 50 amp service. To date we've only had 30 amp models. Question - can you plug a 50 amp unit into a 30 amp service, of course as long as you don't try to use over 30 amps at one time ? Is a costly smart adapter necessary to hook up to the 30 amp service from a 50 amp unit or is it just a plug adapter?
Many thanks in advance,
Marty
  • You can do so much better than spending $30K. I found a 2002 Fleetwood Fiesta a couple of years ago with 15K miles on it. Granted the Fiesta isn't the high end of the Fleetwood line. I'm on a Workhorse Chasis but not the Allison Tranny. Has 8.1 Ltr V8 with plenty of power to climb pulling a toad. It's got the GM Truck 4 speed. It has all the normal things you would expect and actually a very nice unit.
    Anyway, I wound up paying only $18K. and got a brand new Master Tow Dolly with it. So, they are out there. Like I said mine in nice and plenty or room for wife, me and a big dog. I did replace the tires though.
    Came with these upgrades....
    2 flat screen TV's
    Tow Dolly
    Drawer bank under the couch
    Stainless steel back slash around kitchen sink
    Brand New 15K BTU A?C on roof...ducted
    4 outside back up camera's. Front, rt side, left side and rear w/color monitor
    New plank vilyl flooring. Old capret gone.
    New Interstate Batteries (2)
    All service records and receipts came with the RV from day it was new.
  • Thanks for the info Jim. I'm just not familiar enough with the Ford V10's to make an informed decision, whereas I know I'll be pretty safe with the 7.4L & 8.1L GM. I've looked (online) at some of the PA's and they are beautiful.
    The unit we get must have at least the one big slide, and some of the units we've looked at also have a bedroom slide which is very appealing for more room/storage there.
    And about slides - One more question I have is that if a unit has two slides, on opposite sides of the unit, does this further limit the campsites available due to unit width?
  • Never any plug problems on our '99 either at 87k miles. The V10 F53 chassis would be my choice from the handling to fuel mileage & resale.
  • my experience was with a 99 pace arrow. A v10, 275hp, with the short reach plugs.
    I never had a problem with the plugs, period. I had one cracked exhaust manifold but it didn't leak so I ignored it.
    I bought a tuner, which helped power a lot, and also helped the trans, not downshifting nearly so much, which did help the sound level in the cab.
    The 97-2002 year range puts you right smack in the middle of when slideouts first started showing up. I like slides, the more and the bigger the better. Free Space. Some will disagree.
    Our PA was a top of the line gasser. Double pane windows, washer dryer, genie, powergear levelers. VERY nice coach, for a 1999 gasser. We looked at Damon, Thor, Forest River, not even close in quality.
    At 30ish, you might be able to get a DP. I'd lose the slides to get into a DP if I had to. The difference is amazing. The ride. The power, the silence. A thousand ft-lbs of diesel torque, 40 feet behind you at 2000 rpm is "just a bit different" than a gasser screaming between your legs at 5500 rpm... just saying...
