Apr 17, 2014Explorer
chuckftboy wrote:
one time every year the coils should be inspected and cleaned if needed.
the condensate pan should be flushed with clean water.
all elecrtical connections should be checked for tightness
check the fan blades for cracks or loose rivits. clean them if needed
there are some steel parts that if showing signs of rust should be wire brushed and touched up with rustolium paint
I'm not sure there is a condensate pan on a basement air----condensate water just falls on the ground.
38,769 PostsLatest Activity: Mar 31, 2026
