cgmartine
Jan 12, 2015Explorer
k8devin, even if the tanks are empty, when you are hooked up to a water source, in most motorhomes, it bypasses the tanks and the water flows directly to your faucets. The tanks are only filled from the fill point outside the motorhome. This is where you have a small door that you unlock and insert the end of the water hose and let water flow in until you determine the tanks is full. Since you did not say if you are indeed connected via a hose to a water source like a spigot, I have to assume that is what might be causing the leak because it would create a constant flow of water into the motorhome, which would occur irrespective of whether the tanks are empty, or half empty, or full.
