Bobbo
Jan 13, 2015Explorer III
bsinmich wrote:cgmartine wrote:
k8devin, even if the tanks are empty, when you are hooked up to a water source, in most motorhomes, it bypasses the tanks and the water flows directly to your faucets. The tanks are only filled from the fill point outside the motorhome. This is where you have a small door that you unlock and insert the end of the water hose and let water flow in until you determine the tanks is full. Since you did not say if you are indeed connected via a hose to a water source like a spigot, I have to assume that is what might be causing the leak because it would create a constant flow of water into the motorhome, which would occur irrespective of whether the tanks are empty, or half empty, or full.
I think most newer MHs have a valve that switches to fill the tank and the hookup is the same position for everything. I haven't had a separate spot for filling from a hose since my '76 Fireball.
And yet my 2007 Winnebago has a gravity fill opening, but no way to fill from the shore water inlet. This one is an assumption that it is not safe to make.
To the OP, until you find the source of the water, nothing is going to work but a mop.
