dennislanier
Jan 13, 2015Explorer
Like others have said you have several possible sources of flooding. First thing I would do is flush the toilet with clean water and if the black tank is full you should see water "backing out" of the toilet. The toilet is sealed up so unless water is coming out of the top of the toilet then you should not have a leak there. After that I would start checking all the plumbing under the bathroom sink to check for loose connections, busted pipes, etc. Again if the tanks were overflowing you should see standing water in the sink or shower. Sounds more like a plumbing problem than a tank problem. Let us know what you find.
