Deano56 wrote:
John&Joey wrote:
Did you raise the toilet flange or just tiled around it? RV toilets don't use a wax ring but a rubber seal and the height becomes a key point for sealing.
no I did not raise the flange, was a little leary about doing anything there. The tile is 1/2" higher than before, going to silicone two of the stock gaskets together, tested it out and looks to be good.;
Would you mind terrible taking a picture of that. I'm having a hard time figuring out how that will be a leak/smell proof connection.
