Deano56 wrote:
It's basically a thicker flange seal, I don't see why it would not work if it's installed correctly, same seal just twice as thick.
well, the twin gaskets did not work with the silicone, as soon as I stretched the gasket around the lip on the bottom of the toilet it came apart. The silicone won't hold while the one above is being stretched. I speed off to menards to try a wax ring but they wont fit over the lip on the toilet due to the plastic inside the wax. I'm using super now, so I will see if that works, if not I'm going to take a die grinder and lesson the OD of the toilet lip so the wax ring fits over. Other than that I might have to look at the flange extender kits again. Oh well back at it tomorrow
