Cheryl_B's avatar
Cheryl_B
Bathtub is clogged. Kitchen sink backs into tub.
The tub has always been slow to drain, ever since I purchased it. But I bought a plunger and just went to town on it and it did nothing. You'd see the water start to swirl as it would go down and then it would just stop and I'd plunge it again.
Well, I happened to be doing dishes and when I let the water out of the kitchen sink, I ran into the bathroom and low and freaking behold, the sink water went up into the tub.
WTH is going on?
  • Cheryl_B wrote:
    It shouldn't be full yet but my monitor light doesn't work for either the gray or the black tank. I'll dump it all tomorrow and see if it gets better. Thanks for the advice.
    It's called a "zip it"?
    Yes, Zip It. Click on the link I provided. You slide it down the drain and it grabs hair, etc., when you pull it out.
  • It shouldn't be full yet but my monitor light doesn't work for either the gray or the black tank. I'll dump it all tomorrow and see if it gets better. Thanks for the advice.
  • As you may have guessed by now the grey tank is designed to back up into the tub when it's full.
  • I assume your gray tank is not full?
    Get a Zip It. They're about $2.50 at Lowe's or Home Depot.
    Any hardware store will have them..
