Campinfan's avatar
Campinfan
Explorer III
Nov 03, 2023
batteries in the winter
Ok, so another battery question. The motor home I may buy next week has 2 12 volt batteries in it, not that that makes a difference in my question. I will be storing my unit at home and have a pedestal with 30 amp service.(It was installed when a previous trailer was 30 amp). Over the winter I have some options. Should I leave the MH plugged in all winter and the batteries connected. If I do this, I have a new Battery Minder (not a battery tender that only trickle charges) that keeps the batteries from sulfating---should I attach that to the batteries too or or should I disconnect the batteries, and just use the battery minder. And if I do that, can I leave them in the rig or should I bring them in the house. I am thinking I should bring them in and use the battery minder.
I am open to suggestions. Thanks all.
  • There is no reason to remove the batteries for winter. If you have a smart charger/inverter then just plug in and check the water once or twice during the winter. If you only have a one stare charger, put a timer on its power cord and set it for 2 hours a day.
    My coach is plugged in during the winter and the batteries only come out when needing to be changed. Kip It Simple..........
    Richard
  • I would keep them plugged to shore power so that they are fully charged. I think (?) SULFATING only happen if less than fully charged and high temp
  • Turn off your battety disconnect and just leave the batteries in the MH. No nred for a charger as there is no discharge. If they won't hold a charge all winter disconnected they need replacing.
  • my rv sit,s in a pole bldg coach plugged in eng battery on a tender,do nothing with coach batteries. meter says 13.3 thats ok with me.
  • I always brought my batteries in the garage on shelf with a trickle charger in the winter if I wasn't going to be using it for a while. An ounce of prevention...
    • Cybergrunt's avatar
      Cybergrunt
      Nomad
      Same here. RV and mower batteries spend the winter lined up on garage work bench, all get several hours of trickle charge once a month.
