JanTx wrote:
so many things to learn and remember,, scares me to death!
JanTx,
Actually, learning about your coach is kind of fun. You simply start with the basics and go as deep into what you want to know as you want. For instance, The "house battery(ies)(if you have more than one)are what powers up about 98% of the inside of your coach. That is, just about everything with the exception of the TV, VCR-DVD player, and, the Microwave. Then, in order to power up those, you need 110VAC power. You'll get that power from one of three sourses. One, shore power, two, generator, or three, an "Inverter" that converts 12VDC battery power to, 110VAC power.
Now, this is where most people simply don't go any further in obtaining knowledge. If folks would simply take the time when they purchase a new coach, or new to them I should say, and learn about how their system works. That is, how are my 12V or, 6V golf cart batteries charged? How are my engine batteries charged? Do both the house and engine batteries charge together?
What you accomplish is, not only learning and knowing how your system(s) work but, also, a good possibility of how to analyze them, if something should be acting up or, not working at all. Most of this stuff is not all that hard on RVs to comprehend. All it takes is a little time and, sometimes some coaching for explanation in case you run up against a stumbling block.
Scott
