FIRE UP wrote:
Well Bob,
Let's start out with, what kind of motor home do you have? What kind of and, how many house batteries and, engine do you have? You see, if your rig is a diesel, about 99.9% of them have inverters, NOT CONVERTERS, and, many of them are Inverter/Chargers so, you could be having an issue with that system. Now, if your coach is a gas unit, about 99.9% of them, come with Converters, not Inverters!
So, we need more info on your system before we can give an accurate assessment of a possible solution to your issues.
Scott
P.S. On edit, I didn't know the question has already been asked, sorry.
Scott
In either case, you have a problem with your charging circuit, and whether it's an inverter or a converter, it needs to be replaced.
That's probably what cooked your first set of batteries.
Jim
