wolfe10 wrote:
tropical36 wrote:
Guessing so, it's called the GEL setting.
So, your Caddy has a special setting for AGM batteries.
NO. Charging algorithms for AGM batteries are very close to those for wet cell batteries, NOT gel batteries.
And, if you don't have the optional battery temperature sensor for your inverter/charger, you will need to re-program it as seasons change. Said another way, a fully charged battery in below freezing conditions will be very unhappy at 90 degrees F (and visa versa).
As far as I know it's charging the same and for the wet cells as well, keeping in mind that the starting batteries are wet cell and are all in parallel for a good bit of the time.
Thing is, this coach came with 4 AGM 12v house batteries and 2 maintenance free starting batteries and for the same as it has now, so however it was was set by the OEM, it's still that way using the same inverter/converter.
