ron_dittmer
Oct 13, 2014Explorer III
Batteries: Two-6V In Series, or Two-12V In Parallel ???
Before spring I will be replacing our two 12V Walmart coach batteries. Our 7 year old rig has it's original Tripplite 2000 watt inverter/charger similar to THIS ONE. I was thinking of replacing the two 12V batteries with two 6V batteries as these forums seem to favor 6V in series compared to 12V in parallel. I called the maker of my inverter. The technical person there told me two 6V batteries in series will work just fine with the inverter.
But I have a concern switching from two 12V to two 6V batteries, this in regards to the drop in amp hours. Assumed identical amp-hour ratings, two-6V will be 1/2 that of two-12V. Currently our inverter adequately supplies power to make a pot of coffee and watch TV with a sound system. Will two-6V batteries in series be able to meet those demands the same as the two-12V?
In General....
With a rig like ours that has a 2000 watt inverter and no solar panels, what benefits and drawbacks might there be in using two 6V batteries in series? Keep in mind that we almost never hookup to shore power. Battery charging is done while driving and when parked for days at a time, running the generator.
Will it take more time or less time to charge 6V batteries?
How does the physical size of a 6V battery compare to a 12V? I hear they are taller. Do they take up the same footprint in our battery tray?
I am especially interested in hearing from people who made the switch from 12V batteries to 6V. Also, I'd appreciate your input on the best 6V batteries to buy, where to buy them, and what I could expect to pay per battery.
Thanks!
In General....
Thanks!
