pnichols
Oct 14, 2014Explorer II
DiploStrat wrote:
12v batteries connected in parallel do not need to be isolated from each other and if you used a diode isolator, that may have caused your problem. Diode isolators cause a 0.5 - 1.0v drop, depending on the amperage flow. See: Diodes
Excellent clarification!
(What you say is why I used the phrase "direct parallel" in my post earlier describing how our two 12V RV batteries and engine starting battery were all connected together.)
38,780 PostsLatest Activity: Mar 30, 2014
