Dakzuki
Oct 19, 2014Explorer II
ron.dittmer wrote:Dakzuki wrote:I believe our inverter has a 3 stage charger so I think I'm good there.
Ron, What kind of converter do you have? Is it a multi-stage charging unit? If it isn't I highly recommend you change over to one. They are not inexpensive.
It seems the Interstate battery is a bit better than the equivalent Duracell, but I may get the Duracell anyway to avoid traveling so far to get them, and the Duracell are $50 cheaper for the pair. I seem to recall the Interstate is 474ah and the Duracell is 448ah at whatever the measurement. If I have a problem with the Sam's Club Duracell under warranty, I should be able to replace them on the road much easier.
That should have said not expensive, BTW. A PD4645 (which is what I replaced mine with) can be had for under $200 from Amazon.
It would be a good idea to confirm your converter is a multi-stage unit. The benefits are considerable.
