DiploStrat
Apr 30, 2015Explorer
pnichols wrote:
I'm curious about the PD multi-stage units: How are they at automatically dropping down from their boost voltage to their bulk voltage?
First some terminology. The three, commonly accepted stages for lead acid charging are:
-- Boost/Bulk: Max voltage and current until the battery reaches 80-90% charged.
-- Absorb/Accept: Max voltage, declining current until the battery reaches 100% charge. (This basically allows a surface charge to spread throughout the battery.)
-- Float: Reduced voltage and current. Holds the battery at full charge.
(Some chargers offer a fourth, equalization charge cycle.)
My gripe with the specs on the PD line is that they drop the voltage so much that they basically skip the absorb stage; one reason that their charge times are so long. I know from experience that if my Magnum Inverter/Charger drops out of absorb before the batteries are fully charged they will never reach full charge. This means that you have to pay a bit of attention to the absorb setting, either time or amperage flow, to assure that your batteries are getting a full charge. One reason that lots of folks keep a TriMetric around so that they have an independent opinion of the state of charge.
