pnichols
May 01, 2015Explorer II
rehoppe wrote:
've used a 'Continuous Duty' solenoid for battery isolation for several years. You power/activate, it with a 'switched' power wire. Using this method you only have the excess draw when the alternator is spinning.
Our Itasca Class C came that way as wired by Winnebago - when you turn the ignition switch on, a continuous duty solenoid gets activated to connect together the coach battery(ies) and the engine starting battery. I was under the impression that most Class C motorhomes were wired that way?
I changed out the stock solenoid for a more robust one with silver alloy contacts to stop an intermittent coach battery charging problem while traveling down the road.
