pnichols
May 13, 2015Explorer II
ron.dittmer wrote:
I still need to check my rig's on-board charger/inverter to see if it has an AGM setting.
Probably the most important AGM setting to match up is your onboard charger's float voltage versus what your new batteries require for floating. You don't want to evaporate water out of your AGM batteries slowly over time ... because it can't be replaced.
